Machining for port work
Deets066
AKA Deetsey
11:48 PM
But if your mandrel fit "tight" would it be fine to flush it up like you said before? That shouldn't scratch the plateing and and should be sufficient but just not sure about all of it yet cuz I haven't had any hands on experience with it yet. But it's coming :)
Red97
11:48 PM
MI
I shoot for .005-7 undersized for the mandrel. So I can rock the jug a bit to get the edge.
I also make a wood sanding mandrel .001-2 under to finish the band.
Deets066
AKA Deetsey
11:48 PM
Is the corner on your cutter at 90 degrees? What keeps you from getting into the plateing while cutting?
Deets066
AKA Deetsey
11:48 PM
Slot is cut to put a 3* angle on the tool bit for a nice cutting edge. Also so I don't have to grind the tool bit. Jut cut it in half and install.
Very nice.
What holds the cutter in place?
Red97
11:48 PM
MI
You can see the way the tool bit is ground from factory. Only the top edge and the top point will make contact. The leading edge of the tool bit is on center of the bore. Obviously that tool bit needs to be cut before use. A set screw holds the tool bit.
MG2186
10:48 PM
Summer,IA
this works also if you don't have access to mill the slot
Deets066
AKA Deetsey
11:48 PM
So that notch on the side that I'm seeing is where the set screw goes in?
Moparmyway
Its just a saw
11:48 PM
In a meeting
GoBigBlue1984
Bluegrass Fart Knocker...
11:48 PM
Kentucky
Why do you think +/- .001 is close enough?
.001 either way is overkill here. I'm all for precision, hell its my job. Many times to .0002. If I'm only talkin' a thou or two on saw mods that's close enough.
GoBigBlue1984
11:48 PM
Kentucky
Deets066,
Are you trying to "plunge" the cutter into the squish band?
Using the whole width of the cutter to cut the band?
If that is the case no "bar" is going to help.
You have to start in the center and feed it to the wall just like cutting on a lathe. Prepare for lots of broken carbide tips doing it by hand.
Best I can tell, from your video, you could set the depth of cut say.005-.010 with the cutter in the chamber feed it till it takes a cut in the band.
Spin the head till you feel no resistance, turn the Allen wrench a bit towards the wall of the jug. Repeat those steps until the band is cut. It will probably tear up quite a few inserts, and be a long slow process.
I don't see any other good way of doing it, also that bar you posted should work using the method I described.
This is a 372 I recently cut for David. I use an 82 degree diamond carbide insert. Yes, Red is correct, start from the center of the bore and feed outwards. Once indicated in I use a piece of paper towards the face of the cylinder and feed outwards until my insert Just touches the piece of paper. This is obviously done with the spindle off. I zero that out and once I touch off on my squish band I feed .005 past my zero and I take .010 DOC until my desired spec is met. Takes 10-15 minutes if that.
