I've always seen a plate like you're talking about bolted to the jug. Cut squish. Put a mandrel in the bore, Chuck up the mandrel, and cut base. Too much flex to mount directly to the fins. And I don't think I could trust threading into 1/4" of aluminum. But yea, I see your point. Once and done would be niceView attachment 12983
Here is a 660 jug in an independent 4 jaw chuck. I also have a rotary table to attach the chuck to. What would be the easiest way to clamp the jug? Right now the grooves in the jaws lock into the fins making it unable to level up.
I've been thinking of making a universal plate to set jugs on with slots to bolt the jug to. In order to do the base and squish at the same time I thought about tapping the mounting holes in the base so I wouldn't have anything stickin out past the base. Thoughts?
They use mandrels for cutting based on a lathe, that wouldn't work to well in an end millI've always seen a plate like you're talking about bolted to the jug. Cut squish. Put a mandrel in the bore, Chuck up the mandrel, and cut base. Too much flex to mount directly to the fins. And I don't think I could trust threading into 1/4" of aluminum. But yea, I see your point. Once and done would be nice
I will probably make a plate, but if I just bolt it like Randy does then how do I cut my base? The base holes would need to be threaded so there were no nuts above the base.Deets, it's like every other shortcut. It's probably not gonna work.
You gotta make a square plate like Randy does, drill holes, thread holes, bolt jug up with some type of spacer above the top that will allow the jug to move by adjustment of the bolts.
Center it with the 4 jaws and then square it with the bolts. Rinse and repeat till it's right.
You could conceivably cut 4 pieces of aluminum stock and place around jug so the teeth don't screw you up. I'd be worried about broken fins. I know a guy that can fix em for you though![]()
I've been thinkin the jug will sit much flatter if I surface the top of jug first, same thing kindaI contemplated welding a piece of round stock to the top of the jug, turning that square, the flipping the jug over for machining.
Theoretically, it should square the band perfectly.
Then try it with some aluminum stock or oak between the Chuck teeth and jug.
