Log arch thread
hoskvarna
1:07 PM
Iowa
Here it is hooked up
Tried to load video but it won't let me.
Sent from Hoskvarna Hills
2:07 PM
Isn't that angled bar designed to give a little lift to the front of the log when you pull it??? In other words, shouldn't you have it a bit tighter?
TreeLife
I'm Dominick
2:07 PM
How do you like that 240?
Ironic you posted this today Heath, have been using it for the past two days. It's a bad little skidder. When we bought it we found out it had upgraded axles to support dual tires for swamping. I like that skidder, strong, well made, good winch too.
hseII
Heef
2:07 PM
West Georgia
I want one.
I [emoji173]️ 4bt/6bts.
Woodpecker
Sassy Madam
2:07 PM
Anyone have one of these from Country ATV? I like the tire size, but trying to figure out how you would modify it to support a 8 ft log off the ground. It's designed to lift the front of the log and skid the back.
I've run my friends a fair amount and it's built like a tank. Works pretty well with just a 4x4 atv.
Ronaldo
1:07 PM
Eastern Iowa
These work pretty slick as it takes most of the weight off the ground. You can skid a big load with an ATV/UTV.
Sent from my SM-S320VL using Tapatalk
XP_Slinger
They’re Just Saws
2:07 PM
Central NY
Cool thread. I’ve been thinking about building an arch and there’s lots of good designs to look at in here. My little Farmall Super A definitely doesn’t cut the mustard when hooking up to anything big...maybe I should buy a new tractor too:)
Woodpecker
Sassy Madam
2:07 PM
Absolutely. Pulled 12'6" long by 20" oak no problem. Rig it right and only the back few feet drag.
TreeLife
I'm Dominick
2:07 PM
Which axles?
Do you know the weight of it?
Year model?
Is it stick steer or steering wheel?
I also love B series cummins, best engine ever made in my opinion.
It's a 92, it has 380 axles under it (but is a 240 chassis), it's a stick steer, weighs in right around 16k lbs wet.
2:07 PM
My Polaris 570 is a little larger than most ATVs (it is not a small nimble one), but you can haul a pretty large log if you keep the front of it from not digging into the ground. That is all my little device is designed to do.
I'll haul smaller logs 3 or 4 at a time. For someone w/o any real heavy equipment, this is the ticket!
My "heavy duty" tools are the 2010 Ford Escape, a Trailer (can haul 1/2 cord), my 22 Ton Splitter and the ATV.
My logging roads would be pretty tough on any road legal vehicle, and I don't own a tractor.
