spencerpaving
- 6:10 PM
- Jan 6, 2016
- central new york
Southern hemispherewhere abouts are you again
As the owner wants to keep it simple & low key, we are only doing a gasket delete.
After measuring squish it'll have .70mm squish clearance, that's a little excessive 4 my liking but...... on with the show.
Setting up degree wheel 2 measure some ports
And roughing in the transfers...
View attachment 57705[/QUOTE
looking forwards to see what the port timing is
if you take too much out of the ports , will it make the saw run hot , so what would be too much on those numbers to throw the cylinder away , im just trying to understand and learn about thisPort timing will be...
Transfers 118
Exhaust 98
Intake 80
It really depends on what you need to achieve!if you take too much out of the ports , will it make the saw run hot , so what would be too much on those numbers to throw the cylinder away , im just trying to understand and learn about this
thanks for that info , it is just what i was after, whats "free port"It really depends on what you need to achieve!
Numbers 4 my hotsaws are way different to these numbers,as is the porting.
Most important thing 4 a beginner is to not widen ports 2 far.... it will "free port" if you do.
A general rule of thumb is 1 up/1 down
1mm up for exhaust,1mm down for intake.
I've done quite a few different models now, changed things around a little,and gained some great results![]()
Lol....it's when the port is wider than , or below the edges of the piston skirt.thanks for that info , it is just what i was after, whats "free port"
thank you , i thought it may have beensome thing like that , but just wanted to be sureLol....it's when the port is wider than , or below the edges of the piston skirt.
I've seen a few cases of both![]()
Let me borrow it, i'll let my buddy run it for a day. He will put that 3 yrs of logging look on it..Lacks character. There's no holes in the front of the cases or recoil. No cracked clutch cover or dented muffler. Operator presence lever is still operational. Top handle isn't on a funky angle. Still all one color. Sumptin ain't right here
That would be correct.... however it's nearly impossible to achieve.Great thread! Very generous in sharing details and great pics.
Jacking up the timing so the transfers are opening before the intake is closed is also a version of "free port"...Correct?
Sub Sub Subbed![]()
