sherlock349
Active OPE Member
- 12:41 AM
- Jan 6, 2019
- Sussex United Kingdom
I have a Jonsered 2054 Turbo that I have owned from new purchased in 1998. It has not had heavy use only used for
Home logging. Recently it started playing up, difficult to start, would start and run and then would not start, eventually would not start at all. I figured it may be carburettor problem. Purchased a rebuild kit and saw would still not start. (I am use to Stihl and have done full rebuilds on them, never worked on a Jonsered) Did a compression test and good at 140psi. Did a pressure and vacuum test and neither holding. Thought it might be seals or intake boot. Checked intake boot and all appears okay. Removed clutch to check clutch oil seal. Seal is okay but soapy water bubbling at base of cylinder behind clutch casing. I was surprised to see a leak in this area and it looks to be cylinder gasket. I seem to remember reading this is a known/common problem though. I am going to tear the thing apart tomorrow but just thought I would ask here if anyone has experienced this problem or can shed any light on it. Thanks in advance for any replies.
