Inside the.....? (solved, MS 500i)
mettee
8:21 PM
Arizona
11:21 PM
Well, the stock 462 is very impressive … especially when you consider the weight of the powerhead. Glad I got one!
Mason, mine does not feel peaky at all, in fact when I lean on it a bit it keeps pulling real nice … and the throttle response is very impressive.
If it were peaky, it would not have done so well with the 8 pin.
TreeLife
I'm Dominick
11:21 PM
From the little bit I got to use one ( a 462 ) I felt it had great power for what it is. I used it with a 24"RW and a 7 pin. Great falling saw, can't tell if it's real thirsty or if shes got a smallish tank. The last sentence was said by a friend of mine that owns the saw, he would know better anyhow!
11:21 PM
It’s peakier than a 461 but cuts about the same speed. Awesome chainspeed and rpm in the cut for a stock saw. I also did feel the gas tank was smallish, must’ve done that to save weight.
StephK87
4:21 AM
Germany
I'm sitting on pins and needles guys... still waiting for my machinist to get my squish work done :sconf: he had a bad tonsilitis last week and was unable to work on the cyl. But this weekend its time!
Baseline cut's are done on a 28" log with a 28" bar and 7pin.
sorry for skiping the muff mod only, but i'm sure @AlfA01 will do that for us ;)
00wyk
3:21 AM
Ireland
How's it compare side by side with the timing advanced 044?
11:21 PM
Mike. Your 462 should wipe the 044s arse. And take its lunch money twice on Sunday.
If not there is something wrong with it.
You gotta be real here...
