I was first caller this time
old guy
Love me some Husqvarna
3:48 PM
Becker Minnesota
Checked craigslist last evening about 6:00, there was a 550xp about 45 miles north of me.
Saw was seized, scored but he had new oem piston & cyl, he didn't need the saw anymore so was selling, wanted $145. I called & left message, this morning at 7:30 I left another message, at about 10:00 he called back gave me directions, he said there were 17 calls after mine.
Saw looks great, he said the dealer hooked it up to the comp stuff & there's only 22 hrs on the saw, said his relative ran outboard moter fuel in it. he called Husky & complained about a 22 hr saw being toast & they sent new rebuild kit free, oh yeah, it's mine now!
old guy
3:48 PM
Becker Minnesota
I don't do much with pics and it's all tore down now, it's just a nice clean 550, heck that grey clutch cover even looks good yet.
The old cyl. will clean up too.
All the damage is on the exhaust side, it seems if it were bad fuel the damage would be all around but this concentrated at the exhaust port. Before I run it I'll take it to the dealer and have it flashed.
fearofpavement
4:48 PM
Georgia
More likely it was run lean than the fuel was "bad". Unless the fuel/oil ratio was off, using outboard mix wouldn't have roasted the saw. Lots of saw failures show primarily exhaust side scoring only (most of the ones I've seen) and a true "straight gas" event is often scored around the entire piston. (and look for bad bearings too). This "overheat" event is also caused by dull chains, overloading the saw and other operator induced reasons.
Sounds like you got a great deal!
Stihlbro
4:48 PM
Virginia
Awesome find, I have a 550, it is a blast to run. Guy in Tennessee touched it once, it's ran flawlessly ever since.
old guy
3:48 PM
Becker Minnesota
I may have found the problem, I pulled both intake covers and both gaskets had breaks in them. I remember Mr. Evans talking about this.
Has anyone put the 550 together sans base gasket? the gasket is .027 thick, I bolted the cyl. down no gasket and squish is .018, will this fly? will also open up the muffler.
