I was first caller this time
blsnelling
Friend of the Riff Raff
6:39 PM
Franklin, OH
Has anyone put the 550 together sans base gasket? the gasket is .027 thick, I bolted the cyl. down no gasket and squish is .018, will this fly? will also open up the muffler.
There a good chance that the cylinder is no longer setting flush. IIRC, the transfer cover bolt heads are proud of the base of the cylinder. The one on the front right will hit the case as well.
blsnelling
6:39 PM
Franklin, OH
Good to hear. Perhaps that only becomes an issue after the base is cut. I haven't messed with a 550 in a couple years.
Duane(Pa)
It's the chain...
6:39 PM
Centre County
What do the experts say? Is .018 enough for a 50cc Saw?
My gut tells me it is, but I'm no expert...ought to be a rippin' good saw for $150!
Onan18
OPE Sponsor
6:39 PM
Georgia
You also need to check where the cylinder bore extends down into the case, IIRC it will bottom out before the cylinder is completely flush and square with the case. Between that and the fact that the 550 has a know history of the case halves not matching perfectly I would personally run the gasket and use a sealer also.
Joe
Keith Gandy
Maxima K2 40:1 87 Pump Gas
5:39 PM
Provencal, Louisiana
Mine ran fine with the bottom case / cylinder matched and without the basegasket after I fixed the leaking flywheel side seal from the factory ! Then it developed at autotune malfunction which never got fixed at the dealer. Traded that one at the dealer for a 562xp after the techs scratched their heads for 2 months
Keith Gandy
5:39 PM
Thanks for all the tips and advice Guys, but no way am I gonna run .045 squish, that ain't my nature.
Delete the gasket and make sure the transfer covers have clearance as Brad stated and pressure check everything good before reassembly. I use 518 and Loctite Activator when I delete the gasket and has worked well for me. The activator makes a difference
old guy
Love me some Husqvarna
5:39 PM
Becker Minnesota
IT LIVES, got it put back together today, was a little surly at first and ran rich, smoking, hitting the trigger would result in a puff of smoke & silence. After a bit it straghtened up, it still has a bit of a bog but get past the bog & it goes to shreeik rite now. I think it was still compensating for the old air leak.
I don't have any wood here so I can't run it yet.
I was amazed at how little chamfer on the ports on both cyls. almost like none.
Getting all the hoses & wires hooked up is kind of a bugger on these.
old guy
5:39 PM
Becker Minnesota
Took the 550 out to a log pile this morning, it was a little cold blooded at first, it started rite up but needed a couple of minutes before it would pull any revs, but then it was, "come awn boy, feed me wood". I may have a new favorite saw here, ran a tank of fuel thru it, it did stall once when I hit the trigger so I did have to start it twice.
bikemike
5:39 PM
Cottage grove mn
I don't do much with pics and it's all tore down now, it's just a nice clean 550, heck that grey clutch cover even looks good yet.
The old cyl. will clean up too.
All the damage is on the exhaust side, it seems if it were bad fuel the damage would be all around but this concentrated at the exhaust port. Before I run it I'll take it to the dealer and have it flashed.
Damn epa and lean conditions
