- 6:00 AM
- Dec 29, 2015
- Strong Island NY
If the piston is stuck in the jug only, I don't understand why rotating the crank won't lift the jug off of the case.
The piston is at BDC. Unless the crank and case have some foreign material stuck in there as well.
Maybe I didn't read all correctly.
If you 100% can see that the jug is ruined, cut the top off of it, expose the piston crown, drill holes in it. Chop it into pieces until you get the pin separated from the piston.
