exSW
'Cause Thomas is a poopyhead
- 3:30 PM
- Dec 23, 2015
- United States
Dang Husqvarna still makes the 272?
New powdercoat would be purty
I wouldn't do that on a saw that just has the scars of normal use - it removes the historical value of the saw.
Nice bar Ross.Bar finally arrived today. Now I think I got a deal.
That being said, if you want a Golf piston exactly like the one you have there, lemme know. It has 1 tank of fuel on itNice bar Ross.
I put a full skirt piston fron a 266 in my jred 670. I later replaced it with one without the full skirt and gained some rpm in the cut. Meteor makes one with or without windows. You want the windowed one
Gonna need the larger carb to go with the open skirt windowed piston,224..... 224,c.163 will work but not well.Nice bar Ross.
One of mine has an hs260 with jred choke and throttle shafts to retain the high idle function. The other has the original from the 625 that had the same specs as the 260
