HUSQVARNA HUSQVARNA THREAD
Member
9:30 AM
@exSW With Husqvarna still making the 272 a lot of cross over parts should be available to you. Also if you have an ohm meter the testing procedures in the Husqvarna manual for the "G" system is a snap to go through and see where you are at with it. I've done it a few times and the tests were spot on. Good luck with your build! Those 266's are strong saws even by today's standards.
exSW
'Cause Thomas is a poopyhead
10:30 AM
United States
I wouldn't do that on a saw that just has the scars of normal use - it removes the historical value of the saw.
We're not talking about a two hundred year old piece of Shaker furniture here.
Certain things I won't redo. Complete original firearms,most old furniture,trucks , tractors and other equipment that aren't already hacked up. But a thirty year old chainsaw that's going back to work?
10:30 AM
Bar finally arrived today. Now I think I got a deal.
Nice bar Ross.
I put a full skirt piston fron a 266 in my jred 670. I later replaced it with one without the full skirt and gained some rpm in the cut. Meteor makes one with or without windows. You want the windowed one
10:30 AM
Nice bar Ross.
That being said, if you want a Golf piston exactly like the one you have there, lemme know. It has 1 tank of fuel on it
Motorhead
Cantre Member
10:30 AM
Tampa Fla.
Nice bar Ross.
Gonna need the larger carb to go with the open skirt windowed piston,224..... 224,c.163 will work but not well.
exSW
10:30 AM
United States
Don't know what I'm doing yet. The jug looks good. I checked it with the calipers the other day and it's a light 50mm(49.95ish). May just go with a stock Husky slug if available and priced right. With working heat it is a collector saw even if I am going to run it. Why cheap out over 20-30 bucks.
