HUSQVARNA HUSQVARNA THREAD
Sloughfoot
2:21 PM
Norcal
Looks like it is missing 501 41 90-01. Not sure what that little forked pin is for unless it is supposed to be 501 41 90-01, but it looks a bit thin to take on that role, I would expect a thicker pin there.
Yeh, I think that's what it is. I see a fork in the end of the one on the IPL.
Sloughfoot
2:21 PM
Norcal
Making sense now, thanks. Looks like I'm missing what is probably a bolt and nut (501-43-5501). I cut the numbers off, but it looks like the bolt that goes through the taller spring on the other end of the assembly goes through the flag bracket end also. I seeing that right?
singinwoodwackr
3:21 PM
moon
The little fork just keeps the spring aligned.
Sloughfoot
2:21 PM
Norcal
Appreciate the help, Gentlemen. Anyone got an extra flag or know who I can have fix this?
Sloughfoot
2:21 PM
Norcal
@Sloughfoot looks like you got it all figured out. On mine I just used an m6 bolt and nut and used a piece of stainless tube as a bushing. I will try to send you pictures tomorrow. As far as the flag could you just weld a piece of tube into it
Haven't welded something this tedious very often, but if I can find the right size tube may give it a shot.
Sloughfoot
2:21 PM
Norcal
Just weld in a section of 3/8” tube.
Let us know how you bend it. I have one to repair :p
I've got a little bench top bender that I got 4 or 5 years ago and haven't even set up yet. It should make quick work of this. It's the welding part that I've got mixed emotions about.
I'm thinking a matching diameter of solid rod is the way to go. Size it to the i.d. on the one end and insert it 6" or so.
Have @hacskaroly chrome it.
Junk Meister
4:21 PM
Nebraska
Does a Husqvarna 71K (Demo saw)crank and P/C interchange with Husqvarna 371, ?372? and Jonsered 2171 chainsaws?
Tried a search here and found Nothing. May have worded my query wrong.
