HUSQVARNA HUSQVARNA THREAD
av8or3
9:44 PM
Waleska,Ga.
Ran the 2100 in wood today after fixing a few things. Almost all good. Hadn’t tried the manual oiler until now and found it was stuck. Hard. Auto oiler does the job though. Looks like it’s missing a pre filter or something. Any hints on freeing up the oiler? Where to find pre filter? image.jpg
hacskaroly
2100 Fanclub Member
6:44 PM
Northern Idaho, Ehh
No bar studs, strange 'air filter', weird handles, extra holes in the case on the front and more...
Anybody seen anything like this before?
Looks like someone was using it to power something else, like a poor-man's generator.
ErnieG
9:44 PM
Northeast PA
Does the Husqvarna 440 get a rubber buffer on the limiter screw ?
Ernie
hacskaroly
2100 Fanclub Member
6:44 PM
Northern Idaho, Ehh
I don't think so, I have a couple of 372s I have worked on and they didn't have the rubber buffer on this side, just the screw. There is a knob in the inside of the crankcase on the other side that gets one.
ErnieG
9:44 PM
Northeast PA
Yea I knew the 372's don't have one but I wasn't sure if I lost one or there was never one there .
Thanks very much
Ernie
eric4
6:44 PM
Northern CA
Howdy Husky fellas, I'm currently working on a JRed 2171 that's missing a few parts, and was wondering if a Husqvarna 372xp (non x-torq) top cover will fit on the Jonsered even with the j-red recoil.
Figured since my saw is missing the top cover and air filter, I'd upgrade to a high top with HD filter, and dye it black to match.
Cheers!
qurotro
Cookie Cutter
8:44 PM
Ar
Cheers!
If you use the Johnny starter, no. You might find a 372 starter too.
popopboat
3:44 AM
What models use the same crankshaft PTO side ball bearing as 346xp?
Powerstroke Cowboy
7:44 PM
Montana
Good day all.
I bought a "2100/298" cylinder of the bay it showed up yesterday. As soon as it came out of the box I knew it was no a 2100 cylinder, the bore was to small. It's a 285cd, that means a 52mm bore.
The seller said I could send it back for a refund. He feels bad about it. I told him let me check and see if anyone wants it first, it would save him the return shipping.
So, if anyone is interested in the cylinder, it's OEM and the bore looks good. You can have it for my cost, plus shipping.
I can grab pictures if anyone is interested.
I paid 69.00 for it.
sixonetonoffun
8:44 PM
MN
What's the chance 585/592 XP Clutch Cover fitting 365/372/565/572??
Yes those annoying captive nuts are seducing me.
redneckhillbilly
7:44 PM
NW MT
I've got a brand new one if you want to try adapting it to something else, I'll trade it for a chain i can use or sell it for cheap
sixonetonoffun
8:44 PM
MN
Thanks to redneckhillbilly can confirm 585/592 clutch covers with captive nuts will fit 365/372, (jred brothers) & 565/572 saws. 372xpg demo's nicely.
Fit the inner spike as best I could with what I had. Drilled using OEM 372 spike as a pattern and chain catcher holes matched up. Had to grind a little away to fit. Didn't get it perfect depth wise. The height matched great.
