- 3:33 PM
- Nov 24, 2023
- Northern Idaho, Ehh
Nice, I might give that a try!! I like that idea.I’ve plastic welded that exact same spot…as strong as new.
It is a nice kit, got it on AZ.Nice, I might give that a try!! I like that idea.
I didn't look close enough at it, I assumed it said "McCulloch" on it...I looking into the plastic welding kit. Yellow and black, works for me..."and has a patented appearance (Patent Number D970324) for added distinctiveness and Fashion Features." ... well I'm sold!
575286901 husqvarna parts for the toolGuy brought a husky 562 mark 1 in and wants it fixed and for sure it needs crank bearings but not sure if it needs a crank also seems bit loose when tuning flywheel but that could also be the bad case bearing. Anyway what splitter tool do I need because the standard c-clamp style Husqvarna one I have doesn’t look like it will work. Need to get it pulled apart and don’t mind buying the proper tool to do it I have the 357/359 case tools and have only done one so far and may never do another other than the one I picked up for myself but still bought the proper one for 50-60$ do avoid a headache.
Hard to say how long it will last, you will definitely loose compression because of it and the plating may or may not lift from it hard to say. Personally I’d find a different one.Would you reuse this cylinder?
Theres a single scratch/groove on the exhaust side of the cylinder, catches a nail quite a bit.
Will it cause any issues in the longer run?
View attachment 455012View attachment 455013View attachment 455014
Its from a 346xp that i got quite some time ago, decided to get it going.
Besides that groove, crankshaft is a bit sloppy, but otherwise, the saw is in pretty good shape.
Suprisingly 346xp parts are not that common, i guess that it wasnt really popular saw overhere.
It would still pay for itself and I would run it if it was mine.Would you reuse this cylinder?
Very nice saw friend of mine has one I can buy but not near as nicePick up a minty classic, piston and cylinder are like new , View attachment 455385View attachment 455386 compression is great,View attachment 455387View attachment 455389
Yea , I was kinda surprised when I got it, looks much better than I expected in person, gonna do a couple mods but it should be a real nice classic.Very nice saw friend of mine has one I can buy but not near as nice
I would think so if it’s same as the 445/450 rancher like I think it isCan crank seals be changed in a 440 without removing the cylinder ... specifically the clutch side?
Ernie
Very nice! Im currently swapping a 2100 p&c on my 285 cd.....Just That clutch cover complete with the brake lever could pay for all you childrens college tuition.Pick up a minty classic, piston and cylinder are like new , View attachment 455385View attachment 455386 compression is great,View attachment 455387View attachment 455389
Didn’t know if they made a drive in seal like Stihl does so you can repair without splitting
