HUSQVARNA HUSQVARNA THREAD
jacob j.
Only the weird
6:15 PM
Coastal Oregon
No disservice at all @PogoInTheWoods
Fly side bearing is a larger 6203 and not for sure, maybe you can shed some light on the PTO side bearing. It looks larger than a 6203 and I assume is a proprietary bearing.
PTO side bearing for the 385/390 is the same diameter as a 6203 but is wider because it has the seal built-in, so yes, proprietary. It's very similar to the 066/660 PTO side bearing.
timg
9:15 PM
Keystone State West
Thanks for clearing that up J.J.
Sounds as if it's the same PTO bearing as the 575,576's.
PogoInTheWoods
9:15 PM
Ohio
The impulse passage is already through the base, so technically, the answer to your question is "none". If you mean before getting into the actual pulse tube passage, there's probably a few thou there to play with to reduce squish. There are a few threads on the subject if you do some searching.
Stevetheboatguy
8:15 PM
Nw IL
Any of you fine fartknockers happen to have a wiring diagram for a 2020 562xpg?
I have one that has had the grip harness and stuff hacked on. Would like to make sure I get everything back to where it belongs without too much guessing.
Thank you.
Steven
Stevetheboatguy
8:15 PM
Nw IL
You can see the ipl's on the Husky website, if you want pics of the wires I've got a 2019? 562 I can take pics of tomorrow.
Thank you for the offer.
I was hoping for a routing diagram. Or reference picture. I received the saw in a box and I believe I know how they get routed. But the element from the grip has had the red wire cut. I think it goes to the switch, but I'm not 100% positive.
I wont ask you to pull the switch off and check the routing. I'm sure I'll stumble across what I need. It's absolutely a no rush project. Have all summer to dink with it. Just want it 100% for when winter hits again.
Steven
