- 7:22 PM
- Dec 31, 2015
- East Jordan, MI
The numbers as is are probably close enough. The primary transfers are small which will limit the rpm’s a little.Hey
Hey Kevin. Yup that’s the one. Would you have some good numbers without machining?
Personally, I’d hunt for a standard bore 50mm Xp cylinder that looks like yours. Used is maybe $75, new about $140, and readily available. The transfers are already opened up and they’re more modification-ready for a fella that doesn’t have all the tools. Plus, if something goes wrong, you’re not out a cylinder that can’t be replaced for under $300.
