slackinoff
- 11:58 AM
- Nov 24, 2021
- usa
Another question - is a Tillotson carb with the stamping - "s260a030" an HS 260 A carb?
Yeppers. Sometimes the number stampings are not the greatest on the tillotsons.Another question - is a Tillotson carb with the stamping - "s260a030" an HS 260 A carb?
What is that bundled lumber used for? Never seen anything like it before.Been using these alot lately cant complain at all very happy
View attachment 322409 View attachment 322410
I'm not a pro porter but I can give you the numbers I used on mine, Ex 99, TR 117, IN 80 with a .040 pop up piston, 390 carb and the dividers removed from the intake. Here's a video of it so you can see how it runs with those numbers with a 30" bar in oak.This question can go many ways. it’s a simple question with many answers. I have a couple of 372 x-torq’s at work. I started playing around with porting. I bought some tools and have done a lot of research and reading. These saws will mostly be ran with 28” and occasional 32” for falling. Here comes the question- what are good port numbers for a good work saw that can pull a 32” with authority?
Thank you that will help. Did you do a base gasket delete? Without a gasket I have 23 thou of squish.I'm not a pro porter but I can give you the numbers I used on mine, Ex 99, TR 117, IN 80 with a .040 pop up piston, 390 carb and the dividers removed from the intake. Here's a video of it so you can see how it runs with those numbers with a 30" bar in oak.
I cut the base and didn't use the base gasket.Thank you that will help. Did you do a base gasket delete? Without a gasket I have 23 thou of squish.
Better tonight. Tylenol cold & flu is some goot stuff
Hey Kevin. Yup that’s the one. Would you have some good numbers without machining?XPW is the one they quit making a couple years ago. Looks like this inside and is 51.4mm bore
