HUSQVARNA HUSQVARNA THREAD
I saw a lot
8:14 PM
Omaha, NE.
The owner of the Husqvarna 365 Special that is with me for maintenance, my very good neighbor, friend and two decades long firewood supplier, died two days ago.
Funeral was today.
He was 42, fought a long and hard battle against the big C. He was OK for a while, then it all went from bad to worse. :confused:
R.I.P. Antonio :(
He was a huge Scania V8 truck fan.
He found the Dolmar PS-7900 I got recently for me.
Sorry for your loss.
3:14 AM
jacob j.
Only the weird
6:14 PM
Coastal Oregon
Funeral was today.
R.I.P. Antonio :(
I'm sorry to hear Wilhelm, it sounds like Antonio was a fine man. My condolences to you and his family.
M2theB
9:14 PM
Central Mass
I picked up a 266XP today that had some obvious hit scars. Grill broken on the FW and hand bar was skewed. But it ran fairly well so it came home with me.
A couple deeper peeks at home and found some sign of a good deal. Where I’m curious is the cylinder. Dirty at the base butt supper clean other wise. So I started to think it may not be original. I suspect it is original because it is forge marked and stamped at the plug.
Anyone interpret these for me. Is this original cylinder?
2CFC1B7D-2F4A-482E-AAE7-7110790AD1EB.jpeg 765098B2-1EDC-4FC7-8BA6-B5F04C178933.jpeg 692DD32B-FCCE-412A-A954-55212DC458FF.jpeg 6FA99893-D8D3-4ED0-A954-352B3D62E8CC.jpeg 9FBA1DEB-55ED-4D96-B62C-C9129AFA065C.jpeg
qurotro
Cookie Cutter
8:14 PM
Ar
View attachment 315173 View attachment 315174 View attachment 315175 View attachment 315176 View attachment 315177
Looks like a Mahle jug.
Gord
6:14 PM
British Columbia
There was also another company in Germany that was owned by Mahle that produced cylinders fo Husqvarna, can't remember the name.
popopboat
3:14 AM
Is crankshaft the same for Husqvarna 235 and 236?
And what other parts are interchangeable? Only cylinder and piston are different or?
Woodslasher
Teh debil
6:14 PM
Commiefornia
There was also another company in Germany that was owned by Mahle that produced cylinders for Husqvarna, can't remember the name.
The big foreign p/c manufacturers I know of are Mahle, KS (Kolben Schmidt/Piston Smith), and Gilardoni
Maintenance Chief
9:14 PM
South Carolina
ammoaddict
9:14 PM
Granite Falls, NC
Battle Cross 2
9:14 PM
Southern PA
Wolverine
dilligaf
9:14 PM
Yes it runs. I'm gona change fuel lines as it has a fuel leak somewhere around the carb. Probably open the muffler up some and just run it after that.
Thank you for the info I always forget about the acres page.
The 136 I have, I widened exhaust and intake a little along with the muffin mod. Very conservative gains and TBH I wasn't expecting much. If that is your first Hookie, don't judge the brand by it. They are Poo-lans.
Battle Cross 2
9:14 PM
Southern PA
the 36 will get the muffler done and I might play with shaving the flywheel key a little to advance timing figure if I screw it up it's a saw I got from someone's junk pile so no big loss.
I've ran a 359 a few times and a ported 562 and 395. So I don't expect anything about this saw to blow my mind.
Battle Cross 2
9:14 PM
Southern PA
What did your muffler mod entail? I just tossed the spark arrestor in the box of misfit parts and pried the slot in the side open wider with a big flathead. I'm sure theres more flow to be had but it was just a quick job before I took to the woods today.20211109_164506.jpg
