HUSQVARNA HUSQVARNA THREAD
Spike60
6:46 AM
Ulster County, NY
Well I just got a whole "L65" in trade instead of just the air cleaner, and I did a plastic straw measurement of the jug and it mics out to 52 something , so error for measuring device Im gonna assume that someone swapped out the jug and piston in this saws life. One thing the p/o told me is he never saw a 65 with the plug exposed through the top cover.
View attachment 241076 I'm pretty much just learning about the old Huskies though so I'm glad you told me about the casting #s not being related to the bore size.
That plug coming through the top cover means you have an L77, not a 65. :)
Maintenance Chief
6:46 AM
South Carolina
Thanks Bob , I'm just getting into these saws and I wasn't totally sure what it was because of the l65 badge.
Do you know if there's a intake block available for it?
Also if you dont buy yourself an impact driver of some kind I'm going to start a charity to get you one! Honestly I don't know how I lived before these battery operated things.
cornykid75
6:46 AM
US
Can someone help me identify the year on this 262xp. It has the pocket in the tank handle. I see it has the 87 carb. Any guess as to what cylinder it has?
Thanks
Sent from my SM-G973U using Tapatalk
6:46 AM
Here's one of the hl supply 268/272 filters20200520_150621.jpgseems well made
The rubber is very soft on top
I might glue a square of plastic to it to strengthen
It.
But it may not be a problem.
Here's a 97 272 I got for parts20200520_123750.jpgbut after spray foaming and pressure washing it's in great shape
20200520_125021.jpg20200520_134018.jpgstuck ring
I'm going to rebuild it.
MACHINE
6:46 AM
Broken Bow, Oklahoma
The av rubber mounts that go in the tank and secure the body,
Where you get them ? And part number?
Also how you get that color back??? Ir do you repaint?
Sent from my SM-G955U using Tapatalk
MACHINE
6:46 AM
Got the 160S paint mostly removed and she is ready to get a new Base Layer and a RAL 2009 Expoxy Lackr finish afterwards.
What's the color code ?
xsoxso
11:46 AM
Germany
@MACHINE: i will use RAL 2009. Maybe not 100% the correct original color, but fits the husqvarna one pretty well. I will do a complete repaint, ones the weather here gets better. The rubber mounts you can find on ebay. Part No: 501269702
Mean while started fixing the badly messed up ignition coil. Gave it new Isolation on the copper wires and did all the multimeter measurements to ensure its working.
MACHINE
6:46 AM
The 365 a guy gave me is in pretty good shape ,
Rubber mounts have been the DEVIL to find
Bar was bent on it, so a new bar and chain is needed , what length you use??
MACHINE
6:46 AM
Different bushing,
I went to local hardware and found rubber plugs , made the av buffers and worked out perfectly.
P & V the saw a few minutes ago,
Could not be more happy with the test , held both sides of test 5 minutes.
This is going to make a great saw .
Waiting on a tank vent and it will be ready to finish
M2theB
6:46 AM
Central Mass
EBB6ECA7-5D15-4B19-80A3-4F59895AAC1F.jpeg 846E645F-BED4-48C4-B393-E188CCB1964E.jpeg 9B41DCD7-E826-4EFA-B6D7-F14F055D85B9.jpeg 6F24C86E-0B04-4564-B7E5-3596595288AF.jpeg Picked up this 266 yesterday.
Needed very little to get it running. Going to leak check it before I mess anything up.
As seen has some exterior cleaning.
Has the HS 224 and an 8 pin rim sprocket.
Anyone know if the 8 pin was how it left the factory?
Saw seems a lot less used than advertised.
6:46 AM
xsoxso
11:46 AM
Germany
As base i use "Nigrin Haftgrund-Spray". Its a car painting base. As color lackr i will use "Büchner Erbedol" which is an impact resistant machine Painting (Usually used for farm Equipment).
Gord
3:46 AM
British Columbia
should be all spring mounted, lower front tank chain side and upper tank pull start side
