- 12:37 AM
- Jan 28, 2016
- Dike, Iowa
He's looking for a full wrap.
Mark
Mark
I've got one I bought new about 20 years ago.its made alot of money in it's life.only thing I've ever done to it is change bars and fuel filters.The more hours I put on this 390 the more I like it, such a nice saw to run.
Its like a 372 on steroids.
I bet the cooling fins were working at full capacity .
Can’t go wrong with Meteor.The cylinder cleaned up nicely, now I need the piston assembly, intake and carburetor gaskets, base gasket, and a muffler gasket (there was one on the saw when I took it apart but nothing shows in the IPL).
Looks like my piston choices are ProLine, LRB, Highway, and Meteor or the Dukes coated piston. I'm inclined to go with the Meteor but I am open to other suggestions as well. I can't find anyone that has all the parts I need in one stop.
Mark
Did it work?I believe that was an attempt at a pre-filter so the fins don't get clogged with fines...
I like the dukes pistons. He has the coated ones and aftermarket gaskets not sure if you want OEM gaskets or notThe cylinder cleaned up nicely, now I need the piston assembly, intake and carburetor gaskets, base gasket, and a muffler gasket (there was one on the saw when I took it apart but nothing shows in the IPL).
Mark
Is the lip broken off on the left pic , ? ErnieSo both of these are supposedly for the 288 but look different...was there a few different styles of worm gears ?
Thanks
Ernie
The left one is for early 281(8), there's half of the dust shield on the oil pump, its a silver ring pressed in. The right one is the later one. They DO NOT interchange because the pump gear is in DIFFERENT pitch.So both of these are supposedly for the 288 but look different...was there a few different styles of worm gears ?
Thanks
Ernie
