- 2:23 AM
- Jan 28, 2016
- Dike, Iowa
It's not worth fixing just send it to me and I will dispose of it properlyA local guy dropped this off on Friday, says "It need an overhaul". I haven't even pulled the muffler yet but he said the piston was badly scored.
Assuming worst case scenario, where do you go for piston/cylinder, seals, gaskets, etc.?
Thanks,
Mark
I check Duke's first:Assuming worst case scenario, where do you go for piston/cylinder, seals, gaskets, etc.?
Different intakes on the 394 and 395.Not sure if the 395 cylinder will work on the 394, looks like the gaskets and bearings are the same...
THE DUKE'S CYLINDER KIT FITS HUSQVARNA 395 395XP 56MM $70.00
Edit: Don't forget to use "Sawsalvage10" when checking out and get 10% off each item ordered.
Good to know!! Thanks!!Different intakes on the 394 and 395.
Did he leave you a $500 deposit?A local guy dropped this off on Friday, says "It need an overhaul". I haven't even pulled the muffler yet but he said the piston was badly scored.
Thanks,
Mark
Made a decomp button for my buddy's 372 out of a 45 acp case, cut the case in half, filled with plastic mix, after curing for 48 hrs drilled a hole in it and mounted it with epoxy, we'll see if it holds up and for how long, hope he likes it.
