Husqvarna C83 the best?
Jake Dykstra
7:29 PM
NW Washington
Any body else think this is the best cutting, smoothest cutting, fastest 3/8 chain there is right out of the box?
Sure I can make a square ground cut faster but for factory chain it really is quite good.
Always liked stihl rs 23 or 33 but have really come to prefer C83.
4:29 AM
Husqvarna X-Cut Full Chisel 3/8" (whichever designation that relates to across different gauges) is hands down currently the best performing chain under all imaginable conditions.
I love it!
P.S./Edit:
Simple round ground profile does the trick, or round filed who prefers it over grinding.
PA Dan
10:29 PM
White Oak PA
C83 or C85...they both cut great off-the-roll. The only off-the-roll chain that cuts faster (and I can't seem to replicate) is the Stihl .325 RSP chain. Even my square ground Oregon .325 chain can't match the RSP...comes close, but doesn't exceed it.
When the 23RSP first came out I bought 2 loops. Did test cuts with one then square ground it. Did timed cuts with both on my ported 346. Thought something was wrong because I didn't get it any faster.
Duane(Pa)
It's the chain...
10:29 PM
Centre County
Same here. I have nuttin for better speed than factory ground RSP. Most chain starts to shine as the tooth gets shorter. I don’t have any shorter than half, goes back to long life alloy. PaDan gave me a pretty fresh loop in a saw deal. I know it now has no less than 15 tanks on it and still very sharp. Obviously cutting clean (oak) and being careful. I have wrecked other loops and it suffers being physically smaller than 3/8
Squish9
2:29 PM
The factory grind doesn't work well for me (stupid hardwood) but the both the C and S 85 chains are great to use. I like huskies NK and 058, 325 semis as well.
Nice to file, cut well, feel great. It's well made stuff
ZERO
Simple Life
4:29 AM
Woods & Mountains
The factory grind doesn't work well for me (stupid hardwood)...
1+
To be able to land at Sydney Harbor and have someone take me to the true outback, awesome.
To look around and see: no people, no electricity, no cell phone signal, and no civilization, would be nice.
All that's left: heat, sand, cangaroos, and them hard woods to cut.
That would be a dream come true, even on a factory grind.
Freak007
9:29 PM
Minnesota
I've heard a ton of great things about the Husqvarna X-Cut chains. I'd be open to trying it, but I prefer semi-chisel, and all my bars are .050. It seems that S83 is only available with the guarded drive link. My go-to has been Stihl RM33, but it seems that isn't what it used to be.
I do have a MS361 that needs a new bar. Maybe it's time to start the transition to .058...
farminkarman
I like the red & black ones
9:29 PM
Neenah Wisconsin
I would stick with 0.050".
FergusonTO35
10:29 PM
Boonesborough, KY
Until you get bit by a snake that is!
Colonel 428
10:29 PM
The loops of chains I have right now are the Husqvarna c83 xcut and the Duke's original chain. The Duke's chain is basically a copy of the xcut with the exaggerated top plate which makes both it and the xcut very aggressive out of the box. Probably have 9 or 10 loops of each brand currently and have easily used up 3 times that in the past. I cut all hardwood and honestly can't tell a difference between the two in how they cut or retain an edge. Both are excellent in my humble opinion.
sundance
10:29 PM
SW PA
So, 18-20 loops of chain? Easily used up 3 times that in the past? I'm in awe (unless its been numerous years).
Colonel 428
10:29 PM
Lol. Not hard to do if you cut a lot of logs on the ground and only run sharp chains. I wouldn't very awed by that number - more of a testament of me not doing a very good job at keeping my chain out the dirt and swapping chains often...lol.
