Husqvarna 550xp
angelo c
Coal Member
10:51 PM
Keith,
Just curious but, did you , or can you, take a tach to the idle to get a Idle RPM....
I had a similar problem on a saw a few weeks back ( NOT A/T) and it turned out to be a washer was misplaced( reversed) on the clutch assembly.
I wish there was a way to bypass these A/T sensors so you can eliminate the Computer from the "problem".
Can I get a "horseshoe or handgrenade" for being "close"????
Glad you got it Keith....it's not easy to look past the computer for problems sometimes.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
9:51 PM
Provencal, Louisiana
Well when u mentioned washer I had to go back and take a look. With the clutch cover off and with the saw cranked I couldnt hold the drum still at idle
psuiewalsh
Basement Bodging
10:51 PM
Nottingham,pa
Excellent detective work. I have one here that acts like it runs out of fuel when starting cold. It starts fine on high idle once it has been going. It seems like if I get it to start and give it gas instead of letting it sit on high idle it is happy. I took the carb apart and pressure tested the fuel line. It is a little annoying but it cuts great once started.
angelo c
Coal Member
10:51 PM
Well when u mentioned washer I had to go back and take a look. With the clutch cover off and saw cranked I couldnt hold the drum still
I often stare at IPLs ....sometimes they are screaming "hey you donkey !!! look over HERE !!!"
No not over there......HERE.....
Keith Gandy
9:51 PM
Sounds like he's real up to date. Probably be better off sending it back or buying the software yourself.
Ya Mike we dont have a full service Husky dealer here. I havent seen any Autotune products here anywhere. The dealer that I called that had never heard of Autotune was also over an hour away. Work on it yourself or send it off if u have an Autotune down this way
CoreyB
9:51 PM
South east iowa
Wow that sounds like my area. There is more echo and dolmar support in my area then husky. And Stihl is everywhere. Lol
