Husqvarna 550xp carb fix
barton174
7:46 AM
Central Indiana
In this case i bought the stoppers and plates from husky. I think it was $25 or so.
Sent from my C771 using Tapatalk 2
I don't suppose you know the part numbers for those blockoff plates, do you? They don't seem to be in the IPL or the manual (which just has the IPLs).
Thanks,
Mike
6:46 AM
Thanks,
Mike
Welcome to ope Mike.
@Tor R , @Onan18 , do you guys know these part numbers?
I'd like to get a set of them too.
barton174
7:46 AM
Central Indiana
Thanks!
As an update, it appears that the intake blockoff plate has been replaced with: 574 71 14-02
Mike
Onan18
OPE Sponsor
7:46 AM
Georgia
From the Husqvarna site this morning:
1X) Cover plate, inlet - Closure of inlet - 574 71 14-01
1X) Cover plate, outlet - Closure of outlet - 578 04 18-01
2X) Cover plug, inlet - Closure of inlet - 578 02 13-01
1X) Pressure tester - Pressure testing the cylinder - 503 84 40-03
Joe
barton174
7:46 AM
Central Indiana
When I put this (Cover plate, inlet Closure of inlet 574 71 14-01) into the search on partstree, it says unavailable. When I put it into the search on Jack's small engines, it shows up as:
"Husqvarna 574711402
574711401 has been superceded to 574711402"
Mike
Tor R
Novice, Leg model #2
1:46 PM
Mandal
Thanks,
Mike
welcome to OPE Mike :)
members on OPE is awesome, he already got all the answers before I even could type :)
I'm waiting for the plugs myself, forgot to order them when I bought the plates ;)
Stackowood
4:46 AM
West coast
Are the 550 block off plates designed to also work on the 555/562?
barton174
7:46 AM
Central Indiana
So... The 1/4 turn on that screw under the brass plug fixes the "cuts fine and idles fine, but has a bog off of idle" condition?
As an aside, I already checked/yamabonded the base gasket and transfer covers, and am ordering the covers to make sure I don't have a vacuum leak from crank seals or something, though the saw has like 6 tanks through it so I doubt that. Was fine for the first few tanks, then I took it in to get the warranty/updated cover with the hole in it, and they put the new software on it and it now does this.
Mike
barton174
7:46 AM
Central Indiana
I played with mine again. It seems like one turn out is a good setting to start with on the screw. I tested the saw for leak and it did not move after 10 minutes. Vac tested the fuel line and same. No leaks. Put on a different carb I had purchased. No issues. Maybe at some point I will go back and try the old carb again. For now I need some long term evaluation of the newer carb. I checked the lever heights in the carbs. They both appeared above flush with the center of the casting. My W gauge does not cover this series so not sure what the measurement should be. Last question is the valve sheet in the carb. It is the blue plastic type. I thought that in the past these were not good for the 199's anyway.
Thoughts?
Just opened mine this evening. It was 3/4 turn out, so I backed it out 1/4 turn, making it an even 1 turn out. We'll see how it runs, tomorrow.
Mike
barton174
7:46 AM
Central Indiana
That didn't fix it, BTW. Haven't had a chance to mess with it other than that, due to pulling a muscle in my back on Sunday. I'm going to vacuum test it before I mess with any more adjustments, though.
Mike
barton174
7:46 AM
Central Indiana
OK, so interestingly enough, I got the plugs and covers, and the thing pressure and vacuum tests perfectly. Since it ran perfectly fine when OEM, then only started having this issue when I took it in to get the updated/warranty top cover for the vapor locking, and they put the new software on it, I really wonder if there wasn't a carb update in late 2015 or early 2016 (mine is a Walbro 7A 520), and the new software on the old carb is the issue. I'm going to try going into 1/2 turn on that screw (1/4 turn in from where it was, to go richer on the mixture, since mine seems like a lean bog), then I'm going to hit up my local dealer and see if they can put the older software back on it. It'll be a scholastic exercise, if nothing else. These can't be this finicky.
Mike
barton174
7:46 AM
Central Indiana
Finally got a chance to run it. Put it back together, like I said above, with the screw at 1/2 turn out (1/4 turn in from pre-set of 3/4 turn). It's not quite perfect, but it's MUCH better. I'll probably put 1/8 turn more in on it and run a couple tanks through it and see where it's at.
Mike
