slackinoff
- 11:06 PM
- Nov 24, 2021
- usa
I think if you use the non impulse 254 J-red carb, you can use a 268/272 block and everything else works as is.What choke rod do I need for my 625 to 272xp hybrid? It's the hs260 carb.
Bummer…was hoping for sleeker like the 625 above630 or 670 due to the plug angle, a 266 will as well, but those are drying up like rain in the desert.
HS260a is off a 268xp, so you'll want the Husky choke rod for it I believe.What choke rod do I need for my 625 to 272xp hybrid? It's the hs260 carb.
I think the grey was black when new 40 years ago, I think that is how they age….Looks like the smaller CC Jreds have a lower sloped back that almost matches handle height and the 670 has a boxier top with just the corner knocked off. I think the one I have is the lower sloped one - which means I want a black 61 top. I used to have a dark grey top - is there a true black? Thanks
Thanks Spike, I forgot to mention that.The first 670's had a box style filter all it's own, and that was the original reason for the taller filter cover. Didn't last long, and they quickly went to the same filter for all 3 saws. (As well as the 830 and 930) But the 670 kept the taller cover for whatever reason.
That early filter is NLA of course, but worse yet is the the stud spacing is different and later filters don't fit.
You guys remember that the filter covers fit either twin or single coil cylinder covers, but the cylinder covers themselves don't interchange between them, right? Those dark gray 61 tops only work on the twin coil saws of either brand. Only bringing that up cause it looks like that IPL is for a single coil saw.
Somewhere in here I have posts showing different cases have meat to drill and tap and some don’t.Of course with just a bit of case welding, drilling and tapping, every cover fits every chassis….
The late model 61’s (orange) fit the 272 jug on the single coil chassis…
