67L36Driver
6:42 AM
Freaking homeowner Husky all together and the POS starter won’t stay engaged to turn it over. [emoji2959][emoji2959][emoji2959]
With no plug in it!!
We bent on the dogs and stuff but no joy.
67L36Driver
6:42 AM
One thing I have discovered on this homeowner Husky is you don’t get WOT unless you load the bar in a down cut. It’s due to the anti vibe between the rear handle and the engine body.
This makes an up cut problematic as the harder you pull up the less throttle you get. Like half or less. [emoji2959]
Might check that 346 Matt. [emoji848]
67L36Driver
6:42 AM
Now we have a bar stud that jumped ship. [emoji90]
It was there a while ago and now gone. Maybe inside the oil tank. [emoji1696]
And the last chit head to use it was running drain oil.
Freaking wonderful.
Hedgerow
6:42 AM
Lol..
that 346 ain’t even got the same intake tract.
Up cuts are good..
KS Plainsman
6:42 AM
Well today is going to be our first day it doesn't break 70 this fall! THANKFULLY, I think we are passed the bad stuff. The heat and humidity hung around a little longer this year than normal, but I think it waited to start warming up in the spring, longer than normal as well.
Looks like corn harvest is just about full bore here!
Have a great weekend everyone!
Workshop
6:42 AM
Nixa, Mo.
How do you synchronize them?
4 individual vacuum gauges is the best.
You can do a static by using a drill gauge to set the primary carb then adjust the rest to that gauge. Essentially, all you're doing is making sure the butterflies are open the same amount at idle.
