- 7:44 PM
- Jan 3, 2016
- West of Kansas City
Leg of Lamb?
Leg of Lamb?
Leg of Lamb?
You can get tomatoes too..
Seems they decided to turn red all at once.
Lol..One thing I have discovered on this homeowner Husky is you don’t get WOT unless you load the bar in a down cut. It’s due to the anti vibe between the rear handle and the engine body.
This makes an up cut problematic as the harder you pull up the less throttle you get. Like half or less. [emoji2959]
Might check that 346 Matt. [emoji848]
How do you synchronize them?Morning everybody.
Got the latest Goldwing's fuel issues lined out last night. Had 2 carbs with stuck floats causing fuel to run out the vents.
Now to synchronize the carbs.![]()
The correctedest way is with a flo meter and adjusting the linkage to each carb to equalize the air passing into each carb with the rest.How do you synchronize them?
4 individual vacuum gauges is the best.How do you synchronize them?
