moparnut88
- 7:35 PM
- May 13, 2016
- US
I was trained to use a couple clear pieces of tubing with water in the with each end hooked to vac. Then tune carbs till all liquid is even.4 individual vacuum gauges is the best.
You can do a static by using a drill gauge to set the primary carb then adjust the rest to that gauge. Essentially, all you're doing is making sure the butterflies are open the same amount at idle.
