BrettL
- 4:04 PM
- Dec 16, 2016
- Wichita KS
Morning y'all
Don’t forget to pack a lunch and a pack of smokes..
Could be at it a while.. lol
It would give you the tactical high ground I guess.In KC they would be using it for drive by shooting. [emoji6]
My plan was slab down as far as possible with the Alaskan. Then use my 90° guide which follows a 1x3 right down the center for a beginning to try to meet noodling from each end of a 12 foot log with the 6 foot bar. The closer they are the less waste on the trim it flat 1st slice.Ummmmm. Freehand slab it squareish and then mill?
If ever I have time to make my Mall a runner I'd need a longer b&c, 84" cut wood be enough. Easier to guide down the log rather than across. Field experience uses what's on handYou need one of my Mall 7's with the 144" bar option.
Sent from my SM-T900 using Tapatalk
Is that a dual acting one?Picked this up yesterday. Works very well.View attachment 171665
Looks like a two way wedge, my friend has a 20 ton Powerhorse from Northern Tool, only problem with it is it sits too low to the ground.Is that a dual acting one?
Yes splits coming and going. Seen them several years ago finally found one in my price range cheap.Is that a dual acting one?
