Homelite410
10:34 AM
Belle Plaine
Any time you can get your heat source in the heart and under the house, you’ll get a better, more even heat..
Up north, all the big old farm houses had a basement with a big ass furnace in it. Floors stay warm that way. So does the plumbing.
I’m gonna get a house with a basement some day..
Yup, it runs 85 ish in our basement, Livin room floor is 72 when it's running good! That's just waste heat off the front and pipe.
Homelite410
10:34 AM
Belle Plaine
Matt
plcnut
Jesus is LORD
10:34 AM
Mansfield, Missouri
Morning midlanders!
Take my list to Jack Horner’s for 200t parts again. [emoji37]
Random unsuitable parts from Farmertec.
Cuts into my profit margin it does. [emoji90]
Would a little heat allow that to flex to where it needs to be?
Maybe warm it up a little in a toaster oven?
Hinerman
10:34 AM
NE OK
Well, he told me that after two guys running it continuously for 8 hours, 4 cords of elm, it was leaking some at the valve, which he said he tightened. Then the next day he said the filter had come loose and lost a bunch of fluid, and asked where I kept the extra bucket. I sent a text explaining I'd bought this for my own firewood, not for commercial firewood production, and if it got broken someone was going to have to get it fixed or come split my firewood by hand. He said he started running it only a few hours at a time, and that it worked fine. There is a slow seep at the valve, and the ram connection to the wedge is now wet, but not dripping. Both were not present before he started borrowing it. I'm trying to not be a prick about it, but tearing up other people's equipment is a problem for me. I will let him know he needs to find another splitter to use, and that if our arrangement is contingent on letting him tear up my stuff I'm not interested. He didn't bother to even knock the thick caked dust off the AF of my 026 he had, until I pointed out this is a necessary part of the process. This is an observed pattern of behavior.
I am a little confused. Your "business associate borrowed it to try to turn this enormous pile of logs amassed over the year of tree work into firewood". Are you partners on the wood being processed? Is the wood yours? Is the wood his? Are you good friends? You knew there was an "enormous pile of logs" but you don't want your splitter used for "commercial firewood production"---doesn't make sense to loan the splitter.
Regardless of 8 hours of splitting elm, the splitter should not be leaking from the valve. Unless he accidentally dropped a log on the valve, I don't see how the leak could be his fault. Unless he loosened the filter on purpose, I don't see how the loose filter could be his fault. If the cylinder is leaking, I don't see how it could be his fault. Splitters are built to take some abuse; but, sometimes chit just happens.
Maybe you should thank him for finding the faults while you are within the first year. DHT is well known for exceptional service and standing behind their product. If you think he is actually "abusing" your equipment then don't let him use it again; and I wouldn't blame you. Personally, if at all possible, I would not let a broken machine come between a friendship.
