67L36Driver
- 5:44 PM
- Jan 18, 2016
- Missouri
Re the Menards splitter per John’s question.
Not a tie rod cylinder.
If you lived closer to me, I'd gladly pay you $20 an hour to run your splitter all day every Saturday.@Louie B I charge $40 for the first hour and $15 each additional hour. Its worked out well. The customers have all been happy and the $40 first hour charge covers me in case its just a one or two hour job. Of course, in 3 years I've only had maybe 2 dozen customers.lol I only advertise on Craigslist, I need to see if there's a local facebook page I could advertise on. I should probably make some cards and give them to tree companies too. The original idea was just to help pay for the splitter. Judging by customer feedback, I could charge $20 an hour and they'd still be happy.
Might have to look a long time to find a tie rod cylinder on a log splitter.Re the Menards splitter per John’s question.
I've not seen one.
Yup, one could easily double the cost with the same bore x stroke x rod diameter.
One modification to the Menards splitter I’d make is a collar on the rod end of the tube to prevent jackknife.
Iffin it weren’t so goll darn cold, I’d visit our local store and give it a good look.[emoji37]
I am not saying that either. You could get the screws put to you on that deal. Try splitting Gum, Elm, or even green Pecan for $40/cord...lol. Or, 36" knotty oak rounds.
What type of splitter are you using?
Well, that was enough testimonial for me. Ordered for pickup in a couple of weeks. I like Menards, and feel loyal to them, but this is too much savings to pass up. I get a sore shoulder trying to beat a wedge through a single large elm or red maple log, and this will help.
Do you hire out hourly for splitting?
This will fit well with my tree removal business, once I get it going.
I can see a case for that, so to speak. something to prevent the cylinder from folding up trying to knock apart a knotty old locust stem.Yup, one could easily double the cost with the same bore x stroke x rod diameter.
I can imagine a 14 second cycle would seem like an eternity, but I probably have an optimistic opinion of my speed and stamina.It could possibly work out, but the qty would have to be enough to justify a helper to fetch rounds keeping the splitter busy. large rounds just suck from a production standpoint. I despise anything over 20" for volume of production. Split 2 cycles = 1 usable chunk... Yuk.
My 4 way is useless once they get over 20", but at 18" or less, at least you can cycle once and get 2 sticks, then flip and with one more stroke get 4 burnables. So 2 cycles = 6 usable pieces.
Ideally, it's 1 cycle = 4 pieces.. = 2 + cords per hour, minimum staff of 2-3.
I just use tractor fluid from tractor supply. I've gotten my reservoir tank so hot it would burn your hand without gloves. Seems to hold up very well.Now the question is the hydraulic oil. I am a Mobil 1 loyalist, so the motor part is covered, but I know absolutely nothing about hydraulic oil, except that some people use ATF in place of it. Brake fluid?
6.5 gallons is the capacity. Yikes, I hope it's not too expensive. DHT recommends ATF when it's below 32˚ I can't imagine wanting to change this very often, it's not like switching out a little air dam on a chainsaw...
Stihl Ultra? heheh
Stihl Ultra? heheh
I statrted again a couple weeks ago. Off the smokes, but when Istart getting mad, which always triggers Nancy's PTSD (not from me, from her ex), I take a chew. Might go abck on the gum. Lungs are too durn precious...Its been 2 weeks since I had to stop tobacco.
I haven't killed anyone.
Yet.
Stihl Ultra? heheh
