Ethan Hamby
- 4:08 AM
- Nov 25, 2016
- Calico Rock, Arkansas
the hell happened there lol...
You can do it either way Steve.When hand filing, is it best to push the file away from the bar or toward the bar.
That might not be clear.
Push the file from the front (pointy end) to the back or from the back of the tooth toward the front.
I generally file the chain on the saw unless I've rocked it. Then I'll use the chain grinder. (Harbor Freight). But I'll only grind the top plate then hand file the gullet. The file I like to use is the Stihl file. The one that does the tooth and the raker at the same time.
Honestly, that made me almost spit my coffee out....the hell happened there lol...
Latest round grind for work chains.
I'm using the 1/8" wheel..
They actually cut real well..
30 - 52 - 10What angles?
Pre-mature esquareulation???
With a serious case of gulletitis?
I like that cutter. Looks like it was made with a stihl triangle file.
Probably self fed like a beast.
