Homelite410
8:32 AM
Belle Plaine
Ethan Hamby
8:32 AM
Calico Rock, Arkansas
OK he just told me I have to make them in a lathe myself. *s-word. Lol. OK I guess the next question is what steel stock I need
Ethan Hamby
8:32 AM
Well, I'll tell ya this, it ain't as easy as Scott makes it look. After you have to cut the plated band out of a jug by hand, you'll wish you had a lathe. I still do all of mine in a lathe, even the unplated bands.
if only a table top lathe would work. Still over $1000
MG2186
8:32 AM
Summer,IA
That's for sure! I did a plated Hy-Way cylinder once, never again! That sucked royally! I cheated and just used a pop-up in the other one. Nothing's as easy as it looks either!
MG2186
8:32 AM
Summer,IA
Yes that's what I was insinuating Ethan, you need a lathe to make the mandrel and sanding mandrel too
Ethan Hamby
8:32 AM
aluminum seems to me the best option... Safer for the bore and cheaper and lighter. After all the cutter does the work. This is the bar stock I found
8:32 AM
[QUOTE="Ethan Hamby, post: 261542, member: 2178 need to figure out how to make mandrels to cut the squish lol[/QUOTE] Iam pretty sure it was @Brewz made one out a piston just cut in to the piston top .
