cobey
- 5:54 AM
- Jan 16, 2016
- Pittsburg, kansas
I am truly a spazz. ...
I have no choice but to do
What's right.
What's right.
Is that one of them ryobisView attachment 46800 View attachment 46799
Anybody know what brand of saw this is? Saw in a box it is. My next project to put together. Looks like a LOT of new parts in the box. Cylinder I've got looks brand new and 2 new pistons. Bearings, seals, gaskets. Two air covers in the box. One says Mcculloch the other doesn't say. But two different style covers. I need to get rings for it. Only thing I can't find in a box anywhere. Well, I did find a bag of 6 rings but they won't fit in the ring grooves and, when I put one in the cylinder, the ends overlap by about .005. They won't work. Bore measures 40mm. Ring grooves measure 1.2mm. I plugged those measurements into eBay and can get a pack of ten from hutzle for about $10. My question is since I have a 1.2mm groove don't the rings I need, need to be slightly thinner or are these machined already to fit the groove. They just call them 1.2mm.
One engine cover, that says Mcculloch, gives a model number of MS40A. Cylinder has MS40 cast into it. Closest I can find in IPL's is a 4018. Which gives a part number of 9189-310801-A. I plugged that into eBay and come up with a set of Mcculloch rings but with a different part number and they don't say what the dimensions are for the rings. Plus they're more expensive as compared to the others. $18 for two vs 10 for $10. I know, $18 is not bad but I don't know the dimensions.
I know, you all are thinking "Steve, why on earth are you screwing with this thing". It's fun. I just got done assembling a Husky 51 from its atoms. And had to use atoms from other boxes of atoms to make it a complete runner.
But I had a blast doing it.
