67L36Driver
- 9:04 AM
- Jan 18, 2016
- Missouri
'''Tis the season.
Drug out my Mannheim Steamroller cds.
I got the tree today. It's my newborns first Christmas
Any hardware should have those. Just a 3/4×3/4 barbed steel fitting for underground plastic water line. They're about 5" long, 2.5" for each side. $3 or $4.I saw those at the hardware store. They were about 1 1/2 inches total length. Would probably work just fine. I was hoping for longer to get a better bite. Ill go check Lowe's.
Thanks Doug.
I got a dilemma..
Bought a new wood stove for daughter and son in law.
Englander stove with the secondary burn tubes.
Fired it outside to burn the stink off of it and it won't burn.. Not at all..
Upon further investigation, it can't get any combustion air..
Took off all the shrouds and it's just a steel box.
Factory defect?
Wow.I got a dilemma..
Factory defect?
New EPA regulation. 100% efficiency lolI got a dilemma..
Factory defect?
that's crazy man.I got a dilemma..
Factory defect?
The Madison..Needs more draft more than likely. Which model?
The Madison..
I don't care how much draft a solid steel box has..
You can't suck air through a solid steel box..
I got some choice words to share with the folks at the factory. The doghouse box nor the secondary burn tubes have anywhere to get air from.
Agreed..
But all I got is solid steel box..
Seriously..
