Hinerman
11:23 PM
NE OK
47º here today. The coffee is on for sure.
Sharpened all chains Thursday to start on several pecans and a hackberry a friend had taken down. Worked 5-6 hours on Friday and never cut one piece of firewood. The tree service dropped the trees and limbs on top of each other, across each other, etc. I spent the whole day limbing and dragging tops to a pile. I started strapping and pulling with my truck...not sure I saved any time but saved some energy.
On top of that, I was making a cut and smelled something a little funky. Turned out to be an elm in the mess. Then found poison ivy growing up one of the pecans. Then I got scratched and stuck by thorns from a small honey locust I wasn't expecting.
Wait until I show you guys pics of the stumps.....unbelievable.
67L36Driver
11:23 PM
Brisk out this morning
44 degrees.
Former neighbor down the street his iris is blooming.
Been warm it has.
Hedgerow
11:23 PM
11:23 PM
You all have fun today I'll be moving leaves with the bg 86 before rain tomorrow.
Homelite410
11:23 PM
Belle Plaine
OK fellas..... How does this end cap come off? I have blow by on the piston rings. I have never been into one like this.
67L36Driver
11:23 PM
WAEG (wild ass educated guess) you remove bolt, insert a pin and using the cylinder rod as the fulcrum, turn out the end cap/rod bearing with a pinch bar.
Most all my experience is with tool grade tie rod cylinders. Not much with implement type.
Note: If it has iron piston rings it will always leak by some. Rubber cup seals don't leak by.
plcnut
Jesus is LORD
11:23 PM
Mansfield, Missouri
Can you see a snap ring in the groove between the cap and tube? if there is one, but it won't come out, then you may have to use a block and hammer and drive the end cap into the cylinder and then remove the ring. Some cylinders have a snap ring that you have to slide back by reaching through the oil fitting hole.
