Only the Tony
12:43 AM
Need me to have anything on hand what kinda sides, hardware, that kinda stuff??
I'll throw the turkey fryer burner and pan for the oil bath in the truck. I'll have a couple of pans of hot rolls, butter and the makings for hush puppies. What else will people want? I assume most are not eaters of rabbit food. Have to see if I can churn out anything else. I'll try to remember to throw in some paper plates to make cleanup easy. We got a bunch a while back so I will see what I can dig out.
JimBear
12:43 AM
IA
Usually we are 101 to 103 thousand 😁
You are probably running more than 5 axles.
In Iowa we can run 90k when the governor issues a decree, usually 60-90 days during harvest but fines revert back to start at 80k if you are over 90k.
I saw 2 different scale jockeys cruising around today.
85k or so is about 1000 bu., no reason to get carried away. I was getting 7.3mpg averaging 86k last week. Fuel isn’t cheap & the truck rides like crap on these chitty roads when it gets up around 90k or more.
greystone mountain man
1:43 AM
East Tennessee
We only have 5 axles but TN don't mess with you much on agriculture but we have to watch out in GA.
JimBear
12:43 AM
IA
There are a few 5 axle setups but a lot of the pots here have 3-4 axles & several of the trucks run pusher/cheater axles.
Hedgerow
12:43 AM
I got the paper plates and utensils.
Your plan works good for me.
I’ll just pick up some tater salad and coleslaw if anyone wants it..
Easy peasy..
67L36Driver
12:43 AM
Morning Midlanders!
Got a MS271 and an 026 from Ben Tuesday.
The 271 is near mint (Ben had three. 🫢) so it went on Markeplace directly. 👌
Spent all day giving the 026 ‘The Dip’. Only needed a new rim sprocket and one screw. Surprising 😉
Next dress the bar and touch up the chain this morning.
JimBear
12:43 AM
IA
Morning Midlanders!
Didn’t you get a 461 awhile back Carl ? Did you find that one a new home ?
Just curious if you are moving many saws ?
