Sawdust Man
Manufacturer of Sawdust
12:10 PM
MO USA
Got a little wind off Lake Superior here..
Down right chilly.
Here is a laker with some real history.. still in service.. it was the one that the coast guard sent back to look for survivors of the Edmund Fitzgerald wreck..
“The Arthur M Anderson”..
Gets a special salute wherever it goes..
Y'all bring us some of that northern coolness on your return trip please.
It's horrible here right now....
Only the Tony
12:10 PM
Exactly!
Trouble is, we have an electric range....
Power's still out....but the generator is also still chugging away, so that's nice.
I bet you have enough scraps from your mill to make a fire for a pot. I have three if these I think. Pulled this one over on my face and shoulder when I was a year old. Cut across the bridge of my nose from the pot and scar from the scalding coffee on my shoulder.
JimBear
12:10 PM
IA
Exactly!
That’s exactly why I don’t have an electric stove & I once laid a hand on an electric burner while reaching into a overhead cabinet. :mad: Before I heated with wood, if the juice went out in the winter I would use the oven for a bit of heat, plus you always have the burners for cooking or boiling water if needed. Propane is the way to go in rural homes for stoves & water heaters.
67L36Driver
12:10 PM
Second attempt at nose sprocket replacement is successful.
Doner bar (Stihl) was 3/8”. 👌
I had difficulty with the rivets so took it to A friend with a wire feed welder. Fellows named ‘Steve’ are not to be overlooked. 😉
Ground away the old information.
Now I have a 16” bar needs dressed and a nose sprocket. 😑
