Sawdust Man
Manufacturer of Sawdust
12:07 PM
MO USA
Anybody else get crazy bad weather this afternoon/evening?
We had a doozy of a wind....it was downright alarming for a while there, definitely the worst windstorm I've ever not enjoyed....
We had a few trees come down, and lots of big limbs.
No damage to any buildings or vehicles/equipment, so that's good anyway.
My wife's garden ain't very happy, lots of tipped over stuff out there.
Neighbors had a big tree almost hit their truck.
Power is out, there was at least 4 poles busted off from trees and wind, I had to cut my way to town for gas for the generator...... turns out that was pretty good timing on getting a generator.
It's running one ac, the fridge, a fan, and the well pump....and it ran the milking machine too!
We probably got around 2" of rain outta the deal anyways.
Only the Tony
12:07 PM
Nada. Got a little cloudy this afternoon and then cleared up. Friday night we got the wind and rain. One of my projects is to look for a diesel inverter prior to retirement. I can run it off dyed fuel and knock it off farm taxes.
Sawdust Man
12:07 PM
MO USA
This is the first time we've lost power since we moved in 01/08/2021 but I've been wanting to get a generator anyway, just in case.
Only the Tony
12:07 PM
Had strong straight winds about 18 or so years ago that snapped off several poles for about a 15 mile radius. Two oldest were not very old and I was not going to lose the refrigerator/freezer stuff. Bought a generator that day and used it in stages to run what we needed. Joplin tornado shut us down for several days and various ice storms do the same.
plcnut
Jesus is LORD
12:07 PM
Mansfield, Missouri
We had two storms comes through. We lost power at about 4:20 in the afternoon. It was off for about 2 hours. Then another storm came through later in the evening and power was off until around midnight. I have not inspected for damage yet, but it was very windy.
I am headed out of town all day, so won't get to look around until tomorrow.
This place has a 16KW generator that is hooked to our propane tank and has an automatic transfer switch. I feel spoiled. Power goes off for about 5 seconds and the generator will start, after about 10 seconds of running then the transfer switch kicks over and everything comes back on like normal. The previous owner set it up pretty nice.
nbbt
12:07 PM
5543X, 5644X
Morning fellas. No nasty weather at the in-town place yesterday. Was a near perfect day for getting parts of the to-do list cranked out.
54 - 79/84 today depending on which guesser your listening to.
JimBear
12:07 PM
IA
Morning everybody.
Still no power, but the little generator is still screaming away out there, so we've got water and ac.....now, if I can just figure out how to make some coffee.... 🤔
You need a percolator coffee pot for such occasions.
KS Plainsman
12:07 PM
Morning everybody.
I was just going to comment the same thing, James.
We have hard water here and I can never seem to keep a drip coffee maker cleaned out from buildups. I'll use vinegar and it'll do good for a couple weeks and go back to taking 45 minutes to run a pot.
Point being, I went to using a percolator exclusively, and man, it's way better than a drip pot. Paper filters take away too much flavor IMO. Traps the oils in the coffee. I use either a french press, or percolator now.
Give either of those a try Sawdust Man. 👍🏻
67L36Driver
12:07 PM
My parents had a stove top drip coffeemaker. All glass. Bottom pot got filled with water and top container got the grounds. Big rubber donut in between. Heat/vapor pressure pushed the hot water up into the top container. Removed from heat it trickled down. Made excellent brew.
I’ve seen ‘em at flea markets but the rubber donut is usually trash. 💩
Semotony
12:07 PM
They're ss now and called espresso pots. Lil dif in that grounds are in middle of two perfed circles top n bottom. Funnel is in water in bottom (heated area) pressure pushes water then steam up trew grounds and up toob to the top section. Tube is capped to direct coffee down into retaining area where it is poured from. Was I closer a pic or 2 wood show a better description
Hedgerow
12:07 PM
Got a little wind off Lake Superior here..
Down right chilly.
Here is a laker with some real history.. still in service.. it was the one that the coast guard sent back to look for survivors of the Edmund Fitzgerald wreck..
“The Arthur M Anderson”..
Gets a special salute wherever it goes..
