KS Plainsman
- 12:07 AM
- Aug 7, 2019
- Kansas
And good morning fellas!
Looks good boss!
I've had epoxy crack when used on wood with too much moisture.... don't know what the actual mc was, but it was too much I guess.Poly or Spar urethane has worked.
I would think the epoxy would work as well..
Is that the purpose of a kiln; to prevent the uneven drying problems? Or is it just to reduce the drying time?My theory is, warping and cracking is caused by uneven drying of various areas of a given piece of wood..
Keep it from drying, and you can mitigate the problem.
Seal that bugger up as soon as it’s “dry enough”..
Did you epoxy every square inch of it?I've had epoxy crack when used on wood with too much moisture.... don't know what the actual mc was, but it was too much I guess.
The kiln is what you use to get the lumber to under 10% moisture.Is that the purpose of a kiln; to prevent the uneven drying problems? Or is it just to reduce the drying time?
I believe so... if not, that was most likely the problem.Did you epoxy every square inch of it?
I let a slab go to about 20% then sealed it up a year ago..I believe so... if not, that was most likely the problem.
The lumber was stored in the shop where the ambient moisture was around 25%
It has behaved so far..
No cracks or wharpage...
All sealed, top bottom, edges and ends with 2 coats..
Leave even one end in sealed, and it will behave as bad as it can.
When anchoring a slab, don’t try to keep it from moving.
A couple screws in the center will allow it to move a little over the years without cracking.
Don’t try to stop nature...
Just know what it’s gonna try and roll with it.
Nice, those are hard to find for a reasonable price.Picked up a post (leg) vice the other day.
I am a sucker for vintage tools that are still useful today.
