Hinerman
7:12 AM
NE OK
My theory is, warping and cracking is caused by uneven drying of various areas of a given piece of wood..
Keep it from drying, and you can mitigate the problem.
Seal that bugger up as soon as it’s “dry enough”..
Is that the purpose of a kiln; to prevent the uneven drying problems? Or is it just to reduce the drying time?
Hedgerow
7:12 AM
When anchoring a slab, don’t try to keep it from moving.
A couple screws in the center will allow it to move a little over the years without cracking.
Don’t try to stop nature...
Just know what it’s gonna try and roll with it.
Sawdust Man
Manufacturer of Sawdust
7:12 AM
MO USA
I let a slab go to about 20% then sealed it up a year ago..
It has behaved so far..
No cracks or wharpage...
All sealed, top bottom, edges and ends with 2 coats..
Leave even one end in sealed, and it will behave as bad as it can.
I believe you are absolutely correct boss.
I built a walnut coffee table back in the day before I knew you weren't supposed to glue up wood with the grain going perpendicular to other wood. When the top split..... in the middle of the night.....it sounded like somebody was shooting a 22 in the living room.
Still, I'm wondering what would happen if a feller took a wide slab of greenish wood and sealed it in epoxy.... would it just stay green, or would it buckle or something?
Epoxy is pretty much 100% waterproof..... if it was completely sealed could any moisture escape.....
I might have to try a piece and see what it does..... just for the sake of science.....
