- 7:58 PM
- Jan 22, 2022
- MO USA
Looking good enough to move into.Evening everybody.....View attachment 361516
Got a bit of dirt work on the uphill side of the pig barn.View attachment 361519
And a bit more siding.
Good afternoon y'all. Look at the bar on this. What is this designed to cut? The chain reminds me of the Stihl Rock Boss chain.
Details, details, details. Kinda picky u is.Water lines
Phone lines
Gas lines
Details, details, details. Kinda picky u is.![]()
My dad used to work for a fencing company.It's not my fault dig safe missed marking so much crap.
I always sight in at 25 yards after hanging new glass..Finally found a place that had 7mm-08.
$42/box. Used to buy them $27/box.
Bought 2 boxes. Also bought a BSA bore site to get the scope closer. Last time I went to the range I wasted a full box of shells only to get it close to the target. Hopefully this will get me on paper and finish with just 3 or 4 rounds.
You’ll be on paper and just math the clicks to dial it in 1/2” low at 25..
then make sure the last 2 holes are essentially one ragged hole so you know there’s not some other treacherous issue going on.
Carl, you night want to be careful about that in this day and age!I use the lawn chair & no parking sign on the school driveway.
Remove bolt, sight thru bore at the sign centered with the rifle resting on the lawn chair.
Adjust scope to look at the same place.
You will be within 3” at 100 yds.
Not normally done while school is in session. [emoji849]
Well..... I've never tried it around a school, or with a lawn chair.....but I use the method otherwise and usually get pretty good results.....saves lots of ammo.I use the lawn chair & no parking sign on the school driveway.
A man’s just gotta know where he stands before ironing out loads and technique..I usually step it out, 50 then 100. But I have some old school glass bore sights that get me on a large paper at 50.
My .308 Mauser was driving tacks at 100yrds in 8 shots.
