Hedgerow
- 12:43 AM
- Dec 29, 2015
- SW MO
Set anything on fire??The buys bucked some hay this morning.....
This look like $700.00 worth of concrete??
Between the price hikes and the “fuel surcharges “,
Might as well get a full 9 yards and have an over run dump spot.
Why?
Sent from Hoskey Hills
Nope, but we keep a sharp eye out for it.
We only have 4 cows, and we're trying to cut down on how much they waste, when we put a whole bale in they drag it out and make a big mess.
With the price I'm paying for hay this year I gotta do what I can to stretch it as much as possible.
We're building a pole barn right now, planning to make a keyhole type hay feeder to mostly eliminate the waste.
I paid $65/ bale for these, they're sposta be 4'x5' and 850-900 pounds, last year it was $30-65 per bale for this same stuff.What is hay going for down there ? It’s anywhere from $100 - $125 bale up here for actual hay. CRP hay is going for $65 - $90 bale. Most bales are 68” dia x 5’ w, depending on the forage & the type of baler , 1200# - 2000#.
Most folks around here just use hay rings or hay wagons.
What’s big alfalfa squares going for per ton right now?What is hay going for down there ? It’s anywhere from $100 - $125 bale up here for actual hay. CRP hay is going for $65 - $90 bale. Most bales are 68” dia x 5’ w, depending on the forage & the type of baler , 1200# - 2000#.
Well fellas. Gonna try an employment change for a while at least. Going to work for myself again. We’ll see how it works out. Hoping it gives me more time to take care of stuff around the house and get some more saw time. Gonna be doing equipment work with the machinery I already have along with my welding and mechanic business. Should stay busy I expect.
Wishing you much success. PrayersWell fellas. Gonna try an employment change for a while at least. Going to work for myself again. We’ll see how it works out. Hoping it gives me more time to take care of stuff around the house and get some more saw time. Gonna be doing equipment work with the machinery I already have along with my welding and mechanic business. Should stay busy I expect.
I will check around but I don’t know if anyone up here that does them.What’s big alfalfa squares going for per ton right now?
Not like they won’t hire ya right back if the other stuff don’t keep ya busy enough!!Well fellas. Gonna try an employment change for a while at least. Going to work for myself again. We’ll see how it works out. Hoping it gives me more time to take care of stuff around the house and get some more saw time. Gonna be doing equipment work with the machinery I already have along with my welding and mechanic business. Should stay busy I expect.
We payed $310 per ton for a lower quality alfalfa in 3x3x8 bales back at the end of April, trucked in from somewhere elseWhat’s big alfalfa squares going for per ton right now?
I have no doubt you’ll stay busy.Well fellas. Gonna try an employment change for a while at least. Going to work for myself again. We’ll see how it works out. Hoping it gives me more time to take care of stuff around the house and get some more saw time. Gonna be doing equipment work with the machinery I already have along with my welding and mechanic business. Should stay busy I expect.
