11:35 PM
No rocks, but I had all my shop tools.
Also had quite a bit of lead..... and brass.....and heavy wall tapered steel tubing mounted to walnut...... and all the stuff that goes with it.:sniper:
So I rolled the uhaul across some Cat scales today and it was 20080#. 8000 of it was on the front axle. Truck empty weight is 13140.
Good thing I left a bunch of saws back in Kansas I would of been over weight.
Only the Tony
11:35 PM
On another note...
How many days should I leave that concrete cure before drilling and setting anchor bolts??
My shop floor set for two weeks before I drilled and put in the anchors. Used 1/2 x 6 for it in 4500 psi. And for what it worth Diablo rebar demon bits are where its at.
Sawdust Man
Manufacturer of Sawdust
11:35 PM
MO USA
C'mon man, you wasn't even half loaded. Lol
Did y'all get where you're going?
KS Plainsman
11:35 PM
I've been impressed with every Diablo blade or bit I've used. I'm sold on them.
hoskvarna
11:35 PM
Iowa
Agreed on the bits
I used 1/2 x8” concrete lags and put epoxy in holes also for the new shop after the fire
Must of been good cause it went thru the derecho [emoji106]
Sent from Hoskey Hills
11:35 PM
Workshop
11:35 PM
Nixa, Mo.
On another note...
Generally, as comparison, they’ll let house foundations cure for 2-4 weeks. My shop floor is 4inches. I let it cure for 2 weeks before I started drilling it for bolts. But Jason is correct. You can drill and put anchors in at 2-4 days. Just don’t put them under tension.
JimBear
11:35 PM
IA
