Hedgerow
2:52 AM
I am on the hunt for a husky 550 or 545XP with a decomp button.
Newer the better. But needs a decomp, and the new ones don't have one.
I'd just sell him my 346, but can't bring myself to part with it.
Hinerman
2:52 AM
NE OK
Good morning y'all
Question, my log splitter fuel tank has corrosion. I really can't get to it with a wire brush. Any recommendations on a chemical that might break it up?
I think I remember guys removing rust from chains with a mix of 50% transmission fluid and 50% acetone. Maybe Carl can help.
Hinerman
2:52 AM
NE OK
67L36Driver
2:52 AM
No Carl can’t.
Long story but: My ‘53 Ford 1/2 ton had a very rusty tank after sitting in a corn field for years.
Radiator shop boiled it out but that left a ton of rust powder.
I ended up using an extra large sediment bowel w/filter in line. Plus shut off valve so I could clean it ever so often. Spare Filters in the glove box.
Very frequently. Like coast to the side of the road because the engine died. [emoji90]
Took over a year before it cleared up.
moparnut88
3:52 AM
US
Do the new ones come threaded for one? Or is it a drill and tap situation?
I’ve got a brand new oe 550 cylinder here that has the plug hole in it if you need it. I was saving it for a project but ain’t gonna get to it for a bit.
Hedgerow
2:52 AM
No boss in the cylinder for one. You'll be knocking a flat, then drilling and tapping.
You could do it race saw style with a vertical one.
If it comes to that, I will holler...
It’s for my uncle. He’s 78 this year.. still cuts a lot, but the new markII’s don’t come with a decomp.
I told him the original 550’s had one.. now I gotta find one.. or something..
moparnut88
3:52 AM
US
@BrettL I have used Kreem Products in the past with excellent results.
They have a prep and liner kit.
I think the last time I used it was 30 or so years ago, man am I getting old!
But not as old as Carl….
Was that product white or cream colored one coated inside and done? If so I used that product as well many years ago with great results.
Only the Tony
2:52 AM
Never seen that b4. Looks promising. Have you used it? I could use that on a cat pony gas tank I’ve got that needs patched.
Second the Red Kote. Used it on a tank for 1210 Case tractor years ago that had cracks and still holding strong. Got some on a jacket when doing it and the jacket wore out before the stain did.
srcarr52
3:52 AM
Iowa City
You might want to find a carb model. From mine and others experiences the autotunes don't like to hot start with the decomp button pushed in.
