MACHINE
9:11 AM
Broken Bow, Oklahoma
Good morning Gentlemen!
Been awfully busy lately...
I did get to work a little at home on Saturday, and we got the repaired engine sat back in my Sprinter. We are doing a full emissions delete on it. We welded up some block off plates for the EGR lines, and replaced the CAT with a piece of pipe.
Still have to hook everything up, but making a little progress.
The colder weather has not helped much with shop work.
Deleted wife's ecodiesel.
Made a big difference, more mpg, far less heat under hood and under truck .
Better throttle response
Got 26 with it other day
Sent from my SM-G975U1 using Tapatalk
moparnut88
9:11 AM
US
Who did you use? I’ve gotta do my wife’s ecodiesel Jeep
MACHINE
9:11 AM
Guy here in Broken Bow, he's damn good and does a BUNCH , he is even doing tractors , people are having hell with new tractors with def and regeneration filters
plcnut
Jesus is LORD
8:11 AM
Mansfield, Missouri
Those guys have got to lay low right now.
The Biden admin is whacking them hard with fines that shut down their businesses.
It is sad to see.
Green Diesel Engineering had a great tune for these Sprinters, but they can't even sell it anymore...
MACHINE
9:11 AM
It is sad to see.
Yep.
But what's mores costly for environment, motor that won't last. Def is a bad fluid. Less mpg ?
It's designed for a motor that runs at speed for long distance, wife drives a half mile to work, and she will not Rida a bicycle,,, hussy
plcnut
Jesus is LORD
8:11 AM
Mansfield, Missouri
Yep.
That is the part that really gets me.
The environmentalists arguments don't add up.
It is all about money and control.
moparnut88
9:11 AM
US
Ok awesome! Only other place I had found was ecodiesel owners Canada. I’d rather do business with someone state side. How much is the tune? Does he have the delete pipes too?
MACHINE
9:11 AM
Full delete, collector removal, block egr cooler or remove, laptop tune ,
Ours is not one bit louder call me 580-212-0285 or text I'll face time you let you listen
Workshop
8:11 AM
Nixa, Mo.
I now have real world experience with the Van fuel economy. I know overall numbers will be slightly lower than the 2 stops I made on the way down here.
1st tank fill. 13.2 mpg
2nd tank fill 14.4 mpg. And the second tank included the typical horrible driving getting through the Nashville/Murfreesboro corridor. About 60 miles of the worst stop/go driving I've ever seen. By the time I was through that mess I needed a shot or two of human antifreeze.
MACHINE
9:11 AM
Where?
Nashville Arkansas?
67L36Driver
8:11 AM
Took a course in I C engines at Rolla circa 1965.
Along came all the bull chit emission crap early ‘70s.
I’m like WTF? Burn more fuel to reduce parts per million. Just put out more parts entirely they did.
One point in compression ratio in the 8-10:1 range was good for an increase in brake thermal efficiency of 7-8% per point.
EGR further reduced efficiency. Retard timing further reduced mileage.
[emoji90]
hoskvarna
8:11 AM
Iowa
It is sad to see.
Cash under table?
Sent from Hoskey hilltop
