Only the Tony
3:45 PM
Made an air tight, 2 man blind for the north 80..
It’ll be mounted on an 8’ platform.
Will have heat. Just in time for “whack a doe” season..
That will happen in some form here next year. I've put it off long enough and I'm tired of the cold since I work in it all the time.
Hedgerow
3:45 PM
Semotony
3:45 PM
We put a hardwood floor in it.
3/4” oak..
That box is a heavy bastard.
Dig your heels in when you fire a stout load. Reduce impact against black wall if office chairs in use.
Loaded sum fast powder loads for a buddy. Other buddy out shooting with him sat, leaned against tree. Hehe. Said that must been hot stuff! lol
Workshop
3:45 PM
Nixa, Mo.
Did you get the van fixed Steve?
Yep, I did.
There are 3 speed sensors on this thing.
The one on the differential is for the speedometer and abs.
Then there is one on the output shaft of the transmission and one on the torque converter shaft at the front of the transmission. These send information, along with a few other sensors, to the PCM that tells the transmission when to shift gears. It was shifting 1st to 2nd about 30mph under a very light pedal. Then into drive, 3rd, at 40-45. Replaced the sensors and now it's a more respectable 20 and 30.
plcnut
Jesus is LORD
3:45 PM
Mansfield, Missouri
Good morning Gentlemen!
Been awfully busy lately...
I did get to work a little at home on Saturday, and we got the repaired engine sat back in my Sprinter. We are doing a full emissions delete on it. We welded up some block off plates for the EGR lines, and replaced the CAT with a piece of pipe.
Still have to hook everything up, but making a little progress.
The colder weather has not helped much with shop work.
