Hedgerow
11:44 AM
Got one thats about got me stumped. Working on a 268xp husky. Put a 272 piston and cylinder on it. Went to start it, and wouldn't fire. Checked and no spark. Thouht id checked it before, but ok. Put a coil on it off of a parts saw, and still no spark! Ok, dug up a 3rd coil, no spark again! Checking it with the switch wire disconnected, and coil gapped the thickness of a business card. Any thoughts?
Zero thoughts on the explained situation...
If no spark, you got a bad coil, flywheel, or a bad switch.
67L36Driver
11:44 AM
Solid state ignitions don’t make a good spark at cranking speed to begin with.
Try a well grounded (vice grips) new, dry plug with a narrow(ish) gap.
I’ve had to turn off the shop lights and close the overhead door on some. [emoji34]
JimBear
11:44 AM
IA
Monday, a/c compressor crapped out & welds on a marker mount broke so I got 104 acres knocked out & Tuesday had a shaft bearing seize up but still got 164 acres done. Maybe today we can get by without any breakdowns.
MACHINE
12:44 PM
Broken Bow, Oklahoma
Had a Honda 5.5 washer motor yesterday, no pump on it ran great ,, pump on it full load , it would run 5 minutes then start popping and would die ..
Rarely see a bad plug but it was , the only thing I could tell was the plug smelled like bad old gas , like varnish, NGK as well .
New plug fixed
Sent from my SM-G955U using Tapatalk
Workshop
11:44 AM
Nixa, Mo.
New plug fixed
Sunday I was running a Kohler M18 engine that came back from the dead. All of sudden it just died. I thought "Nuts". Found no spark, changed the coil. Still no spark. Tried yet another coil. Still nothing. Grabbed another pair of spark plugs and installed them. It started. Never seen 2 plugs go bad at the same time.
67L36Driver
11:44 AM
There are some saws the cylinder and spark plug hole are surrounded by plastic. The 660 EVL Echo. [emoji2959]They defy placement of the plug or lead to check for spark. [emoji2959]
I’ve one of them in line spark checkers but it only lights up with an old magneto ignition.[emoji37]
MACHINE
12:44 PM
Something in gas , has to be
Workshop
11:44 AM
Nixa, Mo.
Got the engine set down in the newest 317 this evening. Hooked up the drive shaft and started it.
Nothing blew up.
And the hydrostat actually works, too.
:aaaaa:
This one will get a deck. Be a grass cutter down at the stamp.
11:44 AM
White men can't jump, so 8'!
Sent from my SM-N975U using Tapatalk
*B-S....! This white boy can.
Well it takes 67 drivers for a 16” x .325” on an 026.
Baileys changed their bar/chain selector for the worst. [emoji90]
[emoji2959][emoji2959][emoji2959]
Yes it has.
