countryhog
BTDT
10:29 AM
NW Arkansas
countryhog
BTDT
10:29 AM
NW Arkansas
should I just get some parts online, after looking they are very inexpensive, and its not a saw a plan on really using. I was just going to use it as a project saw to learn on.
Are you the progeny of digger’s dad. If so, give my regards to marc
Either way, welcome to ope
67L36Driver
10:29 AM
What are you looking to learn..??
Step 1.. check compression..
Step 2... check for spark..
If ya got spark and the comp is close to 150, the carb is suspect.
The 136 has some parts in common with some Poulan saws.
Carl can fill in those details.
No he can’t. [emoji6]
The next 136 thru my door will be a first.
I tend to avoid small Huskys that resemble plastic Poulans.
Hedgerow
10:29 AM
Hedgerow
10:29 AM
shiosheng Ignition Coil for Module #530039143, 545199901 545063901 for Husqvarna 136 137 141 23 235 236 240 26 36 41 Poulan pro 2600 2775 2750 2900 3050 2500 PP255 PP295 Chainsaw Parts
Supposedly these are all interchangeable.
67L36Driver
10:29 AM
I just avoid them all...
10:29 AM
The carb and compression were good, it has no spark I think that is because of a bad ignition. I was just looking for a little practice on something that was not to expensive which is why I chose the 136, it was $15.
Unplug the kill switch at the coil. I had a 41 do this to me recently.
WKEND LUMBERJAK
10:29 AM
West of Kansas City
Just waiting on this implant procedure to happen.
They don't seem to be in a rush for anything.
Not really complaining, though. They've been good to me. Just want to go home is all.
They must have found out you have stellar insurance.
