countryhog
BTDT
- 4:10 AM
- Jan 19, 2016
- NW Arkansas
Bullseye. 50 rounds with a max score of 250. Mixture of prone, sitting, standing. Qualified as marksman, 190 - 210 out of 250
They have you use the M-1?Bullseye. 50 rounds with a max score of 250. Mixture of prone, sitting, standing. Qualified as marksman, 190 - 210 out of 250
I'm not sure but I think,with countryhog being a Marine back then, it would have been an M14.They have you use the M-1?
Or were they using 5.56 already back then?
Good evening y'all. Picked up an exc condition 029 for $100. Is this one of the Stihl models that had problems? I'm thinking it was ignition related?
Best thing for an 029 is an 039 top end and a muffler mod.Good evening y'all. Picked up an exc condition 029 for $100. Is this one of the Stihl models that had problems? I'm thinking it was ignition related?
Steve, it won't kick like a 45/70 built on a 98 Mauser action. Owner had it loaded max. You know I'm husky. First shot was all needed. Had a medium resist/squish shoulder pad between my shoulder and the stock. 350 grain projectile from a bench, leaned down low. Touched the powder off and from leaned down to sitting straight up! Just a stout push!!I got the critter back out and started looking things over. I decided to put some gun oil in a few choice spots. Seems to have helped quite a bit. I have no doubt that at least 50% of the problem is me, though. After lubing things up
And cycling the trigger a bunch (not really sure if you're supposed to do that) and getting my trigger finger better positioned so as to squeeze it better it seems to let off a lot easier. I have a bad problem of while I'm squeezing I'm anticipating the gun going off. This thing kicks harder than anything I've shot before.
I'm thinking I need some educating on this gun.
Shorter recommendation, find a shoulder pad that eases the felt recoil, or add more weight between the hand holds. Another is to find a gunsmith who can machine, out on the barrel, near the very end openings that send gas back at an angle toward back. Those are the assists I recall now.
Good luck young man
Happy birthday sir!Morning everybody.
